This command allows you to select the number of overhead bytes that will be included in the rate calculation.
rate-limit | Rate limiting features. |
overhead_bytes | Number of overhead bytes used in rate-limit and meter calculations. |
20 bytes to include the preamble and inter-frame gap.
The following example displays the output of the show forwarding configuration command with the rate limit information included.
L2 and L3 Forwarding table hash algorithm: Configured hash algorithm: crc32 Current hash algorithm: crc32 L3 Dual-Hash configuration: Configured setting: on Current setting: on Dual-Hash Recursion Level: 1 Hash criteria for IP unicast traffic for L2 load sharing and ECMP route sharing Sharing criteria: L3_L4 IP multicast: Group Table Compression: on Local Network Forwarding: slow-path Lookup-Key: (SourceIP, GroupIP, VlanId) Internal lookup tables: Configured Setting: l2-and-l3 Current Setting: l2-and-l3 Switch Settings: Switching mode: store-and-forward L2 Protocol: Fast convergence: on Rate Limit: Overhead Bytes: 20 Fabric Flow Control: Fabric Flow Control: auto ARP and ND Settings: ARP Suppression Filters: per-port ND Suppression Filters: per-port
This command was first available in ExtremeXOS 21.1.
